Originally posted by: JM Aggie08
Thermaltake A2018 Smart Fan. Available in multiple sizes.
80x25
17dBA at 1300 RPM~
48.5dBA at 4800 RPM
90x25
17dBA at 1300 RPM~
48.5dBA at 4000 RPM
120x25
17dBA at 1300 RPM~ (mine)
46.5dBA at 2800 RPM
The fan is very quiet and comes with a controller which goes into an expansion slot. Also come with three different functions.
Here ya go
Also available @ the Egg.
Originally posted by: Painman
Yate Loon 120s don't work with Thermalright's retention clips due to the way they mold the fan body 🙁 quite a shame since they're a good value. Akasa looks very good.
Maybe we can all send the OP 2 bucks via Paypal to get him to be our Scythe fan guinea pig 😀
Originally posted by: GalvanizedYankee
Akasa 120x25, 44cfm@18dBA http://www.sidewindercomputers.com/
It has a tach/sensor wire and is a high quality ball bearing fan both should be present
in a CPU's HS fan.
...Galvanized
in a CPU's HS fan.
...Galvanized
A friend just got one of these. AWESOME fan to say the least.
Direct Link
Here you go:Originally posted by: Painman
http://forums.silentpcreview.com/viewtopic.php?t=18368
