Quiet cpu fan for Athlon
newz54
29
I have a stock headsink/fan on my 1.2 athlon. The fan is clearly the loudest part of my system and I would like to replace it with a quieter model. Can you recommend a heatsink/fan that would deliver about the same cooling power as the stock parts but be much quieter.
Cerb
17,484
33
86
Thermalright AX-7 + Panaflo L1a or Enermax 80mm adjustable
Thermalright SK-7 + same (slightly higher cost, much more availability)
SLK-800 + same (overkill)
SLK-900 + same (overkill)
huesmann
8,618
Not overkill if you o-clock.
newz54
29
Can I just replace the stock fan with a quieter fan (panaflow or?). I guess I would need some sort of adapter as the stock fan looks much smaller than 80mm. btw...I am not overclocking.
BoomAM
4,546
The SLK-800 with a YS-Tech Silent 80mm (27CFM, 20dBa) is perfect imo. Excellent cooling even if you dont OC.
Theres no such thing is "Overkill" as far as im concerned.
Thump553
12,837
2,621
I know what you are going through-I built an AMD 1.1 retail system for my daughter and couldn't stand the high-pitched whine of the retail fan. I replaced it with a similar size fan I had sitting around.
See my thread here for my story of the Thermalright 800A and a Panaflow L1A on an AMD 1.4-short answer is it probably won't cool enough:
Cooling a 1.4
I replaced the panaflow with a regular, generic 80 mm fan and my temps dropped 12-14 degrees. You are probably looking at a total of $15-25 for the parts needed, but it will be worlds better as far as noise and temp.
Wigwam
943
if all you want is quieter stock cooler then why not just get a spire falconrock2?
it is [a little] better than stock but SILENT and best of all it is about £5 so very cheap too.
0roo0roo
64,795
84
rip old fan off by any means required. add low speed panaflow or stealth vantec using screws, superglue, expoxy, velcro, duct tape, whatever. done! its a 1.2ghz, its not worth more effort or money then that.
