Hello all.
In the past 9 months I have had to RMA 3 brand new hard drives because of bad sectors and other failures. And now I'm about to rma a 4th one !
This is really making me sick inside my stomach... I figure that it may be caused by overheating at this point. I have a coolermaster stacker case with lots of fans inside. I also use a 4-in-3 hard drive case that came with the stacker. And i've fitted 4 hard drives in there so they are very close to eachother.. I figure this is probably a bad idea. Even with a fan sucking hot air from the 4-in-3 and blowing it out.. it's not a very fast fan.
So I've decided to expand a bit on room.. gonna use up 4 bays instead of 3 so my HDs have room to breathe. And while I'm at it.. I'm looking for a good cooling solution to insure all my HDs run cool in the future. I'm looking for something quiet.. not silent but.. not too noisy. I've seen a few so far but I'm wondering if any of you have anything to suggest ?
Thanks, I appreciate it
