soundasleep
Putting together a new build & trying to decide on a case & PSU for a quiet (not silent) system with decent cooling for my situation:
- No overclocking (stability & reliability is key)
- Primarily for music production / light video editing
- somewhat high ambient temp. for part of the year (Los Angeles)
Trying to use quieter/cooler components:
i5 2500
ASUS P8P67
Sapphire VAPOR-X Radeon HD5770 (should be cool & quiet, right?)
Crucial RealSSD 128GB OS & programs
WD Caviar Black 2TB (x2) media drives (non-RAID)
ASUS DVD burner
I was trying to keep the case and PSU each to $100 or less, but I would potentially spend more on something like an Antec 183 ($136) if it was deemed the best option
PSU: Cooler Master Silent Pro M 600W or ??
Im leaning toward adjustable fans since the ambient temp. and CPU load will vary, so the Cooler Masters may be out. Heres my current short list:
Antec Sonata Elite - $90
- 1 rear 3-speed 120mm
- 1 slot 3-speed 120mm exhaust blower
- side vent
Antec P183 - $136
- 1 rear 3-speed 120 mm
- 1 top 3-speed 120 mm
- 2 front (optional) 120 mm fan for HDD
- 2.50 Internal - 2 x 2.5" for SSDs
- Dual chamber design
- Three layer side panels
NZXT H2 - $100
- 2 120mm front fans, 1200 RPM
- 1 120mm Rear fan, 1200 RPM
- 1 140mm top fan, optional
- 3-speed fan control for all fans
- Noise dampening foam - front & sides
Antec 300 - $60
- 1 rear 3-speed 120mm.
- 1 top 3-speed 140mm
- 1 front (optional) 120 mm (HDD).
- 1 side (Optional) 120mm (GPU).
Antec Solo - $90
- 2 front (optional) 92mm
- HDD suspension system
Cooler Master HAF 922 - $100
- 1 front 200 mm Red LED on / off fan / 700 RPM / 19 dBA (can be swapped for 120 / 140 mm fan x 1)
- 1 top 200 mm / 700 RPM / 19 dBA (can be swappwed to 120 mm fan x 2 )
- 1 rear120 mm fan x 1 / 1200 RPM / 17 dBA
- 1 bottom 120 / 140 mm fan (optional)
- 1 side 200 mm fan (optional) (can be swapped for 120 mm fan x 2)
Cooler Master Sileo - $100
- 1 front 120mm
- 1 rear 120mm
i5 2500
ASUS P8P67
ASUS DVD burner
- side vent
Antec P183 - $136
NZXT H2 - $100
Antec 300 - $60
Antec Solo - $90
- 1 front 120mm
- 1 rear 120mm
