- Oct 26, 2000
- 347
- 0
- 0
Okay, here's the scoop. I'm a broke grad student 3 months away from being a less broke graduate. In the interest of saving money, I'm looking to convert my current comp into a quiet PC worthy of serving as a HTPC. Looking for input, here's my setup:
Antec 1030B
ABIT KT7ARaid
1GHz TBird clocked at 900MHz
GlobalWin FOP32
4 7200 Harddrives, 1 DVD, 1 CDR
Fans:
1 80mm Antec in HD cage blowing in
CPU 60mm blowing down
PSupply blowing out
1 80mm Antec right beneath PS blowing out
MBMonitor shows 48 CPU / 27 Case
Globalwin is Louder than hell, other seems to collectively create noise but not to the level that the others do. I'm looking for some input on he following items.
1) First I'm looking to ditch the CPU fan for one of my 2 unused Antecs. Does anyone know where to find cheap 60/80 adapters? Should I just replace it with This?
2) I read a post about cutting the honeycomb punched grills in the back and replacing them with These. Will this significantly reduce the noise?
3) Any experience with ducting systems like These?
4) Any good deals on Rounded cables (should help with cooling right?)
Any other input much appreciated...1030 owners?
The name of the game is "As Quiet As Possible" without toasting my CPU or HDs.
Antec 1030B
ABIT KT7ARaid
GlobalWin FOP32
Fans:
PSupply blowing out
