Quiet 80mm fans
chari
265
Does anyone know of the quietest fans for your buck. I am a high school student and don't have much money after building a computer. So if anyone knows what are the best fans for your dollars airflow/sound wise let me know please!
AristoV300
1,380
yeah Panaflow's are great. You might look into getting a fan controller if sound is that much of an issue. You probably can pick up a used one for cheap.
klah
7,070
Originally posted by: Operandi
WFT?!, thats an awesome deal!
Saw it in the hot deals forum a while back.
The only caveat is that these are produced in China, there are others that are produced in Japan. Some people warned me that these were not as high quality as the 'japanaflos', but I ordered 20 anyway. I have 9 of them installed in various systems with some @12V and others @5V with no problems yet.
Operandi
I've heard that all the current Panaflows are just as good as the Japanese counter parts. Also all Panaflow production will shifted to China eventually from what I understand.
chari
265
So if i was to get them...do i need a fan controller or what...i dont know how it really works...can someone explain what kind of connectors to use or what...and what a good fan controller would be...Thanks
Operandi
Those are 2 pin connectors, you can plug them into your 3 pin fan headers on your MB but you'll have to make a small modification. You should be able to figure out what I mean from this pic from SPCR.
I really don't think you'll need a fan controller for L1A's unless you?re going for extreme silence but if you do you can always take that on after you have the fans.
Melectricus
420
I bought these at bg micro before and they are nice, buy more than you think you need. I have some running uncontrolled and some on controllers - some bearing noise down low on the controlllers.
As for the pin mod. Take an exacto and cut off the guide tabs...takes 5 seconds per fan then plug into the proper two pins and ignore the rmp pin.
ReiAyanami
4,466
you could buy any cheap fans and then 7v or 5v mod them with a soldering iron, although airflow will be substantially lower (<2000RPM) so i just leave my case open
