quiet 80mm fan for heatsink?
Taylorm
650
What do you guys suggest. Im tired of hearin this delta. So i wanna replace the 80mm delta with a quiet fan. Heatsink is a alpha pal8045 BTW
0roo0roo
64,795
84
pabst if price is no object. any normal fan with controller if you want control or a low flow panaflo/stealth if you just want low flow.
mastay
130
Get panaflo/stealth if you want really quite. Prefer panaflo since stealth are whiny.
Get an adjustable if you just want your computer quite for a part of the day.
Hunt for NMB fans if you want cheap quite.
Or do the 7v trick/ solder resistors onto a fan if you don't want to buy something new.
