Quiet 80mm Fan for Duron 750??
i8mywindpipe
222
Hi,
Can anyone suggest a good quiet 80mm fan to be used to cool a Duron 750.
Ive got a 60mm to 80mm Fan socket thingy for my CPU.
The CPU isn't Overclocked. @ 750MHz
Maybe someone douing this can let me know what they use.
The main thing is quietness.
I'm using Artic Silver 2 as Thermal Paste.
Thanks for all your help.
Sensor
947
I using a Panaflo L1A 80mm fan on the same setup as you and haven't had a problem. The Panaflo is rated 24CFM 21dBa. As such, I'd say any 80mm fan ~ 24CFM will do the trick.
If you're looking to buy one, drop me a PM and I'll see what I can dig up for you.
--Ed
