Well, it's time to finalize the Conroe build... I think I want a 7900GT, but not sure which to get. Ideally I'd like something on the quiet side without having to go with an aftermarket Zalman-type thing (if I had to go for aftermarket cooling, EVGA's warranty is better?)... Overclocking is not a criteria at all.
As I'm in Canada, I'm basically limited to what is available at NCIX.com...
PNY GeForce 7900 GT 450MHZ PCI-E 256MB 256BIT 1.32GHZ GDDR3 Dual DVI-I HDTV Out Video Card
EVGA E-GEFORCE 7900 GT CO 500MHZ PCI-E 256MB 256BIT 1.5GHZ GDDR3 Dual DVI-I HDTV Out RoHS Video Card
EVGA E-GEFORCE 7900 GT KO 500MHZ PCI-E 256MB 256BIT 1.5GHZ GDDR3 Dual DVI-I HDTV Out RoHS Video Card
BFG GeForce 7900 GT OC PCI-E 256MB 256BIT DDR3 SLI Ready Video Card
BFG GeForce 7900 GT OC SIN Edition PCI-E 256MB 256BIT GDDR3 SLI Ready Video Card
XFX GeForce 7900 GT 520M Xtreme 520MHZ 256MB 256BIT PCI-E VIVO Video Card
They probably have a bunch more; those are the ones on their weekly specials. The BFG is the cheapest.
Which should I get?
Which should I get?
