Quiet 68XX / 69XX / 5XX Card for 1920x1200?
Tab
12,145
Hi,
Just picked up a cheap 6850 for $160 from newegg last week, I'm happy with the performance of the card since I don't care about AA or super-high details but damn it's quiet loud - even at idle. I can't find any custom heatsinks for the card that aren't $100+ in which case I should just buy a different card.
Does anyone know of reviews of quiet cards in particular? Google hasn't help me much, if at all.
Keysplayr
21,219
56
I have a GTX570 and it's barely audible at load. Can't speak for the other cards you mentioned. Right card for 19x12.
deimos3428
697
Hi,
Which model of 6850 is it? Some of the early VGA BIOS firmwares had a bug that kept the fan at about 73% when idle. If that's the issue a VGA BIOS update will fix the problem pretty quickly.
blackened23
8,548
Hi,
You won't find one unless it has a liquid cooling block, there's a couple manufacturers that make 68xx / 69xx's like taht but i can't remember who. You can probably run it at 50% fan speed which isn't too bad though, I usually do 50% constant fan and don't have any crashes in games even while oc'ed.
Generally, radeon uses far less power than gtx 570 / 580 , while the latter are quieter.
BFG10K
22,709
3,007
There’s something very wrong there. I had a reference 6850 from AMD and it was dead silent, even under load on a very hot summer day.
I couldn’t hear it unless I opened my case and put my ear right next to it. It was subjectively even quieter than my old 5770 under load.
(sic)Klown12
572
Do drivers control fan speed? I didn't think so, but maybe I'm mistaken. I thought fan speed was a bios setting.
Inside the OS environment, the driver does have control of fan speed. The only time the BIOS is in charge is during the initial power-up as there's no software to control it.
For OP, I would suggest looking at something like Gigabyte's Windforce 3X cards. The cooler on them is great, and with the default fan profile is quiet even under full load. Even in summer here in Texas, I've yet to see my card top 68c and the fan is inaudible from about 3' away with the side on my case.
deimos3428
697
Forgot to mention you can run a HD6850 passively with an Accelero S1 for about $35. If you're concerned about running it 100% passive, you could zip-tie a quiet low-RPM fan to it.
3DVagabond
11,951
204
I'm just thinking if it's drivers then everyone running the same drivers would have the same problem? Or, updating/changing drivers should fix it?
hdfxst
851
I tried to put an accelero s1 rev.2 on my 5850 etreme which is a 6850 with a with a 5850 gpu and you need to modify or change the vrm heatsink to make it work.(it's to tall)
deimos3428
697
I suppose it depends on the model. I've got two Gigabyte 6850s working fine with them.
