firewolfsm
I'm trying to decide between two fluid bearing fans and I can't tell which would be better for me. There are two versions of the S-Flex I'm looking at, the 800RPM and the 1200RPM models, but if the performance hit on the 800 is too much then I can stay with the 1200. Then there is the Arctic Cooling AF12, which has a nice frameless design that will reduce vibrations (which should help because I don't have any pads) but runs at 1500RPM. That might be too loud but the fan could be quieter because of the design. I'm perfectly fine with a 38mm fan.
Then there's this "magnetic bearing" fan I found, it seems really quiet but the airflow it too low. Some searching showed me that there's a version with a knob to control the RPM and raise it higher than the stock 1000. If I could find that I'd get it right away.
Would 44CFM be much worse than 54?
I really want the quietest solution but then again I want low temps too 😀 any recomendations?
http://jab-tech.com/Arctic-Cooling-...12-pr-3297.html
http://jab-tech.com/Scythe-S-Flex-F...1E-pr-3256.html
http://www.monoprice.com/products/p...format=2&style=
And since my motherboard can't do it's own undervolting and I don't have a controller I will be running at full 12V
