quicklaunch box in the wrong place....please help
dmw16
I havent used the quicklaunch box in a long time, but i decided after using another machine tonight that i wanted to use it. So i right click on my toolbar and turn it on, but theres a problem, its in the wrong place. I want it to be right next to the start menu but instead its at the opposite end of the toolbar. I cant drag it to where i want it...all i can do is strech it, but that doesnt help. How do i make it go where I want it to? Im in Win2k if that changes anything.
thanks,
-doug
click and drag the "bar like thingy" on the left side of the quick launch bar over to the start menu area. Or click and drag the left "bar like thingy" on the left side of the task bar over to the right. One of the two.
if you don't see the 'bar like thingy' like n0cmonkey says, you might have the taskbar locked. right click taskbar and uncheck lock taskbar.
