Quickest way to spot an 80-wire 40-pin IDE cable?
SOS
94
Hi,
What's the easiest way to tell the difference between an old 40-wire 40-pin IDE cable, and an 80-wire 40-pin IDE cable?
Hoe do you spot the 80-wire 40-pin cables is basically whar I want to know.
Thanks
SOS
Pretender
Banned
Mar 14, 2000
7,192
For ATA66 wires (I dunno if it's for all 80-wires), they have 1 blue, one grey, one black connector (I don't remember in what order, and I'm too lazy to peek my head into my computer).
HD2GO
351
Count it ... 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 ...... 35 36 37 38 .... 76 77 78 79 80!!
Midnight Rambler
Blue connector goes to the IDE controller connector on the mobo, I think the gray is for Master, and the black for Slave.
