Quick! Ya think a 350w Antec will be enough?
KyleGates
613
So, will a 350w Antec Basiq PSupply be enough for this system?
ASUS P5N-MX nForce 610i
E6300
2 Gigs GSkill DDR2 800
XFX 9600GT
160GB SATA HDD
Lite-On DVDRW
(No xtra fans, lights or....anything)
KyleGates
613
thx, I figured as much but the 9600 scared me jst a lil. Most say they req 400watts but this system has so little in it I figured a 350w would be aight.
lockmac
603
yeh im also curious... i wanna buy this psu as well...my system would be...
Gigabyte GA-MA74GM-S2H motherboard
Seagate Barracuda 250Gb 7200RPM 16Mb SATA 2
Lite-On Super Allwrite SATA DVD Re-Writer (20x/8x Dual Layer Black)
AMD Athlon 64 X2 (AM2) 6000+
Corsair DDR2 4GB PC-6400/800 (2xXMS2 2GB) TWIN2X4096-6400C5 Ram
also... would a 300 watt be good as well? i saw an antec case that has a 300watt psu as well
its just for basic office work this build..
thanks
jonnyGURU
Moderator <BR> Power Supplies
Moderator
Oct 30, 1999
11,815
104
thanks
No graphics card? Sure! No problem.
MustangSVT
11,554
12
thanks
are you the same guy with the psu review website?
love your work!!! very informative. :)
and op, ya it should work.
using 8800gs with similar stuff inside on earthwatt380 and even with o/c it is working well.
