Quick Wireless Network Question
DarkAmeba
581
I just set up a wireless network for my parents. They would like to use the laptop outside, so range is a consideration. I didn't want random neighbors connecting to the network however, so I enabled WPA-PSK. Does this encryption have any effect on the router's maximum range?
febuld
100
I've never heard of encryption affecting range...It can possibly delay speed by a second or two, but range should be fine. Also, there might be a lot of disturbances outside to get a good connection in general. If so, I'd suggest Belkin's Pre-N router. It's a bit expensive, but it's compatible with most, if not all, G and B equipment, and it has extended range and possible speed increases even for the non-Pre-N stuff...
JackMDS
29,563
432
JackMDS
29,563
432
Yeah, you are at the edge of the coverage and your bandwidth is just enough to allow Internet surfing.
Bandwidth is dropped (WEP, Changes in envioroment what ever) No more Internet surfing.
You move closer to the source Bandwidth increases. Internet comes back.
Well in some places in the Galaxy we might call it Distance variation.
:sun:
ktwebb
2,488
Just enough to allow internet surfing? Either you have an association or you don't. There won't be an "just enough to surf". Encryption does not affect range, period.
