Quick, somebody with a v3c razr, I need some help.
DragonShizzle
17
I want to change my ringtone, but my phone was recently ran over, miraculously the phone still works, but the lcd is totally unreadable.
I had memorized the actions it took to get to the list of ringtones, but either I have forgotten a step or I broke something last time I added new tones.
If somebody could either set me up with steps to get there, or possible post screenshots on how to get there I would be delighted!
I'll post some screens to show what exactly what my menus look like and what I've been able to find on google.
images:
http://www.askdavetaylor.com/0...et-tunes-and-tones.png
http://www.askdavetaylor.com/0...3c-set-as-ringtone.png
Also if anybody that wants to help don't tell me how to get to them through "get it now" -for some reason that doesn't work for me, but instead going to the menu then right 2, and from there. THANKS!
foghorn67
11,883
63
the default ringtone for all incoming calls?
-center button for menu
-Directional Right twice. this gets to settings
-number 2 for sound settings
-hit center button for the first option of "ring styles"
-Directional Down for "Master volume detail", hit center button
-Directional Down once for "calls", hit Center button.
That will bring you the list. On mine it shows 6-7 vibe tones, then it gets to the custom ring tones you added. like this
Silent
Vibe dot
vibe dash
vibe dot dot
vibe dot dash
vibe pulse
aimmsg
aimol
aimsys
alert
ambient
bells
bits and bytes
chimes high
chimes low
chord high
chord low
claps
digital
digital signal
ding
door bell
drum
dynamic
fanfare
latin loops
motion
msnmsg
msnol
notify
provincial
razr_v3crings
standard
tada
this is techno
verizon tone
windchime
yahoomsgyahoool
thats the end of the included ringtones for me, after that its whatever you added in there.
-edit--I hope that is what you need, good luck!
DragonShizzle
17
Thanks, now for some reason I can't get to this menu still. The reason could be that I just did like a mass delete of ringtones I do not use (through Windows). Hmmm, I'm worried. I'll mess with it a bit tonight and look to see if anybody has responded tomorrow.
