quick recommendation for case <$60
ariakasRM
I'm looking for a good case without a power supply or fans for under $60. I need a good solid case that won't trap in heat too much (for some reason, according to asus probe, my athlon 1800 is at ~75C) and won't vibrate and cause excess noise.
Thanks.
Originally posted by: Texun
I have this one and I'm very satisfied with it, but it will put you over budget by $5.
Funny, I have the same case as Texun and I was also going to recommend it even before I clicked on his link.
Get the Chieftec... spend the extra $5... It's a huge case with plenty of room inside and great airflow.
