NuclearNed
Raconteur
I think I know the answer, but would like some confirmation:
I have two drives on the same IDE cable. Both have their jumpers set for CS (cable select). My assumption is that this means that the drive on the terminating connector at the end of the cable is considered to be the "master", while the drive attached to the connector in the middle of the cable is the slave. Is that correct?
Is there any benefit to explicitely setting the jumpers so one is a master and the other slave, instead of using the cable select option?
Finally, will a drive have better performance if it is the master, as opposed to being the slave - even if the difference is just slight?
