Quick Question - Saran wrap and CPU
nlh
51
When I was applying the Arctic Silver 3 to my CPU, I quickly dabbed it with saran wrap to spread it a little better. Did I kill my CPU/motherboard? I had it on anti-static wrapping and was using my wristband.
nlh
51
I was under the impression that saran wrap was static. My brother mentioned it so I began to worry. :(
Jan 31, 2002
40,819
Pimpslap your brother. :p
Considering AS themselves suggest a plastic bag, I think you're in the clear. IMO, the whole "Static Discharge" bit is pretty overrated.
- M4H
pm
Elite Member Mobile Devices
Jan 25, 2000
7,419
22
And how did you arrive at that conclusion?
Speaking as someone who has accidently destroyed several CPU's by static electricity I'd say that prudence is warranted. In this case, dabbing a bit of grease on the CPU plate using a bit of plastic wrap is not likely to cause a problem. But messing with saran wrap while accidently touching the pins easily could. It takes very little static electricity to damage a microelectronic component - well below the threshold that you can actually feel. In addition the damage can cause sporatic errors that are difficult to trace the damaged component.
I personally believe that a little static paranoia when working with microelectronic components like memory modules and CPUs is an easy insurance policy against the very real problems that can occur.
Patrick Mahoney
Microprocessor Design Engineer
Intel Corp.
pspada
2,503
It's ^ true, a minuscule amount of static can fubar your components. However you should be alright - it's not like you blew the bag up and rubbed it on your hair. :light:
One rule has served me well over the years: ground yourself out before sticking your hands inside the box. I'm not necessarily suggesting a wrist-band (I've never worn one), just discharging any static by touching metal (a file cabinet in my office works great for me), and not moving around much while doing the work, preventing any additional buildup.
Abhoth
345
Yeah, should be o.k.... But static is a very real danger. I'm a roving tech and generally not too worried about it... but, ground yourself before jumping in, then don't shuffle your feet! Remember a guys machine I worked on a while back... went to open the CD-ROM and got zapped... wore a wrist strap for that one!
Son's machine a few days ago... went to clean the CRT with a damp paper towel. Made the mistake of holding it steady with my left hand, wiping with my right... was like a damn bolt of lightning. About scared the hell outta me... son sitting there wondering where the 5 inch bolt came from! Lucky the monitor still works.
Yeah, static lives so do take care... and it's the ones that don't zap you that will kill the components.
oldfart
10,207
Originally posted by: THUGSROOK
i live in FLA ~ there is no such thing as static down here ;)
Heh...I was there recently....no kidding. Flat as a pancake too. I stood on a beer can and could see the whole state! ;)
Paveslave
180
Patrick Mahoney
Intel Corp.[/quote]
Geez dude, time for a new job...? Several CPU's... I think I would have learned from the first time.
fell8
533
I would try the power switch on the front of the case after the build is complete. If the computer makes it to the desktop, I would begin to suspect that you may not have fried the CPU. However a 72 hour vigil is still in order. Good luck!
DAPUNISHER
31,701
31,568
Even over all the Hottie's :sun:ing themselve's TATA's??? :Q :D And don't for a second belive just because it's flat we don't have good mountain biking, we just dig great big holes in the ground then rid up and down 'em ;)
nlh
51
Thanks guys, that was a late night freakout question on my part.
It was fine, system's running great. I built mine the next day (the aforementioned one was his) and it's fine, just may be a little hot. I think I'm going to redo the AS3 application process.
Thanks for your help and warnings. :D
(I always use my little wristband just to be safe).
oldfart
10,207
Yeah, but the hole fills up with water, then you have the Croc's in there to deal with!
pm
Jan 25, 2000
7,419
22
You handle enough of them, you break a few. <shrug> I wised up and started treating static like it was real after a co-worker and I did a hand-pass transfer while walking down a hallway and zapped a prototype. Before that I suspect that I broke at least one other from static - but I wasn't sure.
Mikki
1,488
Then it's time to call the Croc Hunter!! :p;)
