Hi all, I need to know what is the highest available capacity Memory Stick Duo or Memory Stick Duo Pro? All I can fing is 512megs. Is there any higher capacities available? I want to put some mpeg4 movies on em to play on my psp. Is 512 the highest? Thanks.
4gb is the highest I know. The sweet spot in price right now is the 512mb and 1gig version. BTW, Dell had Sony 1gb Memory Stick Deuo Pro on sale for $96 yesterday.
PSP can use regular Duo or Pro Duo The only difference between Pro and Non-Pro is capacity and speed. Pro Duo goes up to 4gb right now although it's virtually impossible to find and crazy expensive. I'm using 512mb memory stick pro DUO with my PSP right now, and I've Sony 1gb pro DUO on order with Dell.
