Quick question...please try to help, shouldn't take long...
Booty
I'm trying to hook up lights in my computer and just need to know how to wire them to a illuminated rocker switch. The switch has 3 connections, and I can get it to work, except the switch doesn't light up like it's supposed to...so the switch works fine except it doesn't illuminate like it's supposed to. How am I supposed to hook it up? Thanks...
1 connection is for power in, 1 is for power out (to light), other one is or should be a ground for the light in the switch itself... Got ohm meter???
