Quick question on processor and cooling fan
Naeb
23
I have a GlobalWin Heatsink and Fan that I used on my Celeron 366@550. I am upgrading to a FlipChip Celeron 566@850, and was wondering if I can use the same HS/Fan, or do I need a special HS/Fan for a FlipChip Processor.
thanks!
Naeb
23
bump to see if anyone can answer me . . . I'm not positive, but I believe my current HS/Fan combo is the GlobalWin CPM25603-32.
Thanks for any replies!
Marine
330
If the heatsink will fit a socket 370, yes you can use it. Line up the HS on the socket and be sure the step on the socket fits the lip on the HS and that the cpu core is in the middle of the HS. If these all line up, it shouldn't be a problem.
Whoa, I didn't read it carefully. If you are overclocking it to 850, you may need something bigger. Try it and see first and if you can't get where you want to go, buy a better cooling rig.
