Quick Question on Power Supply
imported_Crane
20
Hi.
I have a quick question. I am fixing a pc with an Asus TUSL2-C motherboard.
I believe the power supply is bad.
The mobo does not need the connector for P4 cpus.
I have an extra Enermax power supply that has the P4 connector.
Can I use this Enermax and leave the P4 connector unused ?
minerman
15
Hello Crane, it will not hurt your PS or the motherboard to leave the P4 connector unhooked. If the mb doesn't use the connector it will not even be noticed. Just tie it back out of the way.
YOyoYOhowsDAjello
Moderator<br>A/V & Home Theater<br>Elite member
Aug 6, 2001
31,205
45
yep :thumbsup:
