Quick question: how does a quad pumped bus work?
Darien
So with DDR you use the rising/falling edge of a clock signal. That I can understand.
But a quad pumped bus? How do you get get twice as much data pushed through compared to DDR?
Thanks.
probably by using different voltage levels, but then i'm not an engineer.
i always suspected that intel's rdram fiasco had to do with that quad pumped bus, as rdram employs one as well.
DDR(double data rate) sends two bits of information per clock cycle
AMD Athlon XP fsb is "double pumped" in that it sends two bits/cycle.its real speed=200Mhz fsb, but it's "effective" speed is 400Mhz
quad-pumped, sends four bits per cycle, so the 200Mhz becomes effectively 800
Originally posted by: Darien
Originally posted by: n7
Try Here
This place gets way more traffic
Very true, however the people that DO frequent HT know what they're talking about and you'll get a much more thorough and overall better answer there than here, even if you get a faster response here.
uh it has 4 air bags,and when the bus stops to let people on/off the bus
the air bags deflate,so the people can get onto the bus easier.
Way to live up to your name.
Topic Title: Quick question: how does a quad pumped bus work?
Glad I could help in OFF TOPIC.😉
Originally posted by: FishTaco
EDIT: new link, old link was to quad rate SRAM, this link is to DDR-II which is what I think you're asking about.
http://www.lostcircuits.com/memory/ddrii/2.shtml
basicially, the I/O buffer runs at twice the memory core rate, data is transfered on the rising and falling edges of the doubled core rate, hence 4 possible transfers per core clock cycle.
Thanks! :beer:
ATOT pulls through again!
Hahaha, I was wondering when a reference to Danica was going to show up. Ah, the nef fest on a serious question continues. Next I'll see someone post about how they're in agony for stepping on an ant.
