quick question for T4x owners
stingygrrl
when you look at your keyboard from the cdrom side looking across the keyboard (enter is close to you, caps lock is on the opposite side), are the arrow keys the same height as the pgup/dn keys or do they stand higher? I'm wondering if mine are too high? the other 3 corners of the keyboard seem to be flush with the base. on the other hand the entire machine seems to slope down from the back to the front (hinge to the touchpad end) adn I wonder if the arrow keys should be higher so that it's flat when you use it. the tabs for the KB are in properly I think/
thanks. please let me know. I'd like a few responses so I can guage a consensus.
absolutely higher or higher in relationship to the chassis?
and don't you think this is just a little picky? 😉
mine are absolutely higher than the pgup/dn keys.
I had a little flex under them so I added some foam tape under the keyboard. jut wanted to be sure that they are not too high and going to damage the screen. other than that i don't care 😀
