Quick question does it matter which way I plug my cables in?
spat55
539
Just had a thought and I don't think I've ever researched this but does it matter which way the ATX/PCI/EPS leads go into the motherboard? I'm 99% sure it doesn't but maybe the alcohol has screwed with me too much :D
lehtv
11,897
74
It should not be physically possible to connect them in the wrong orientation. So the question isn't "does it matter", it's "is it possible".
BonzaiDuck
16,676
2,052
On my boards, that's an 8-pin plug wire, and there's only one 8-pin plug for it on a motherboard.
Or maybe I misread what you mean by "ATX/PCI/EPS." That power-plug wire is usually designated as "ATX/EATX." At least, as I recall . . .
spat55
539
I was just interested as I've always put my connectors on with how they have the clip to hold them onto, when I took my PC apart for dusting I had a proper look at all the cables, I hadn't really thought about it in my time building.
