- Jun 14, 2003
- 10,442
- 0
- 0
right just re-applied my 7000cu with AS5.
followed the instructions AS had on their site, though not being a man that eats rice or being able to guess which ball bearing they approximated too, im not sure wether i put too little or too much AS5 on (basically a rougly rice grain shaped blob, with a litte extra added to the side then kinda whipped into a more round shape) and they do know theres like....thousands of different ball bearings out there right lol?
also i had to slide the HSF round abit to line the screw holes up.
jus running S&M now, and its currently 43.5degrees. sound good? do i have to wait for AS5 to "set" or anything?
(PS this is running 2.5Ghz, with a 3.3% boost in v core which everest reports as 1.39volts)
it was idle (at 1250Mhz using cnq) at 30degrees, and was steady at 36degrees (at 2.5ghz after 2 hours of BF2) before i started the test
