Quick question about running my tbred 1800+ at 2100+ speed @ default vcore
duuuma
874
I've got my XP 1800 running at 1733mhz (2100+) @ 1.55 default vcore.
Temp shows 41C on speedfan.
Prime95 ran fine for over 10 hours straight with regular usage also, not a hiccup.
Now since the temps are good, voltage is default, and stability is good also, would you just run this cpu at 1733mhz non-stop all the time? I'm curious as to if you regular oc'ers run your processors at oc speeds constantly or if you just boost it when you play games or what not...
Shimmishim
7,504
i find the most "stable" overclocked speed possible and just leave it there... it's a hassle to restart your computer, go into bios... change your FSB then restart...
duuuma
874
sorry guys, i just saw the official guide by pillage2001, just disregard this thread.
