Quick question about routers and cat5 cables
Szap
I know that in order to connect from a regular port of a router to a wan port of another router, you need to use a crossover cable. I know that it is possible to go from a regular port of one router to a regular port of another router with a regular patch cable.
I would like to know if these two different things achieve the same function or if they performing different functions.
Szap
That doesn't quite answer my questions. Let me see if I can explain it better. You just answered 2 of my questions through private message, and this actually has to do with that. The site that you sent to me said to use a crossover cable to connect the regular port of one router to the wan port of another router.
Regular Port of Router A > Crossover Cable > WAN port of Router B
I am wondering if it is possible to achieve the same results by using a regular patch cable and going like this:
Regular Port of Router A > Standard Patch Cable > Regular Port of Router B
Does that make more sense than my first post?
JackMDS
29,550
425
You have to look at your Router's spec.
If the Router's Switch ports are listed as MDX then it does not matter what you use.
Otherwise you need a Crossover Cable.
The Router is a combo unit. The regular ports are just a simple humble Switch.
The rules of Switch/Hub apply to them just like it is an independent Switch/Hub, and they are listed in the link above.
In addtion if you want to use the Router as a Switch make sure you set it correctly.
Using a Wireless Cable/DSL Router as a Switch with an Access Point
:sun:
