Quick Question About Case Modding w/ Dremel
CarpeDeo
1,778
I just found out that we have a dremel and I want to make a window in my ks282. But I don't have any bits that can cut through metal this thick, so what kind of bit do I need to buy to be able to cut metal?
Tschaft
445
Or just a reinforced cutting wheel....cutting a clean hole is harder than it looks...specially if u only have a one speed dremel.
lotust
9,025
your dremil might not have the power to cut a thick case. some cases are thick and some are very thin.
I use real power tools. my dremil is just for small and fine stuff. I took the plunge and bought some hole cutters and an abror for my drill. this works much better and makes a cleaner hole.
