Quick power supply/SATA question
Deptacon
2,282
Hey guys, stil lshopping for some stuff, im almost done, just chekcing a few more things.
I have a question about the power supply, isnt there a diff power cable (besides 4 old standard 4 pin) for SATA HD's? how do i tell if this one has it, and can i get an adapter plug in if it doesnt, like a pin size adapter, if so where can i get one?
I picked out this case, cheaper and kinda cooler than the silverstone, plus i like the external usb and audio/mic ports on top, not on side.
Case:
http://www.newegg.com/app/view...amp;manufactory=BROWSE
Power:
http://www.newegg.com/app/Show...mage=11-133-125-17.JPG
also decided to get one with a power supply, instead of the seaside PSU one, saved me a good chunk of change doing the cheaper case and power supply combo.
let me know beofre i hit the chekcout button ove rhere on newegg....
D1gger
5,411
The ASUS A8N SLI-Deluxe comes with these accessories:
SLI connector
1 x 1-port IEEE1394 module
1 x SLI retention bracket
8 x Serial ATA cables
1 x SATA Extension module for external devices
4 x 2-port SATA power cable
1 x 2-port USB2.0 / Game module
1 x 2-port USB2.0 module
1 x COM Port module
1 x UltraDMA 133/100/66 cable
1 x IDE cable
1 x FDD cable
1 x I/O Shield
User's manual
Instant Music
Setting Sticker
WinDVD Suite
Anubis08
220
Your Power supply should too. It looks like it will. Go on thermaltake's website and it should tell you. I would suggest getting a case w/out a p.s. and getting an antec true power. They definitely have the connectors. I have one.
Deptacon
2,282
went with the antec PSU like you reccommended, has 2 sata connectors, and higher amp at 12V
