quick oil drain valve?
alpineranger
701
short of something hitting it and breaking it off, I've never heard of people having problems with them
mooseracing
1,711
There is also a Fram one IIRC. Most are just o-rings that need replacing. Oh and alot of people on the thedieselstop run that fumota one.
radioouman
8,632
I have used the Fram one on my boat. I like the Fumoto design better, but the Fram is probably better protected. I bought the Fram from Advance Auto Parts, but I checked about a month ago and they don't seem to carry it anymore.
Demon-Xanth
20,551
I'm half surprised that they don't just have petcock style ones where you'd just pull it out a couple turns and let it drain. (like they have on radiators)
Auric
9,591
Heheh you said petcock. Heheheh!
It adds to potential fail so is a matter of weighing that fact versus suppos-ed convenience in the meantime. There was a recent thread on rage3d about 'em.
drnickriviera
2,457
266
I have the fumoto valve on the ram and love it. I just put a 1 gallon oil jug under it and drain straight into that.
Demon-Xanth
20,551
Originally posted by: AdamK47
This will save you approx. 20 seconds.
I was thinking it'd do more to save in mess since you could go straight into a jug or bottle rather than a pan. Though given how some filters are located, that's a lost cause.
OdiN
Banned
Mar 1, 2000
16,430
Get the one with the nipple and put a length of hose on it, right into a jug.
Also it will save on wear on the threads and some manufacturers have those crush washers that you're supposed to replace each time you change the oil.
Feb 24, 2001
14,513
4
Humm, spend 10 seconds putting a hose on a nipple and into a bottle, or drag out the paper, nasty oil catcher thing, tools and remove the bracket covering the oil pan, etc.
I just wish it wasn't $20
Kroze
4,052
I have it on my car and I loved it. No more mess when changing my oil & it's so much faster to change my oil now.
SoulAssassin
6,135
alot of people put these on their wranglers after installing an oil pan skid plate making it hard to access it normally, they seem to work fine as long as you don't bust it open on a rock
OdiN
Banned
Mar 1, 2000
16,430
That's my only concern with putting one on is that it will stick out a bit more.
Bignate603
13,897
That's what I was thinking. Strangely enough though, the guy that owned my CJ before me didn't put in a guard over the oil pan, he welded 1/4" steel TO the oil pan. I had to teflon tape the oil plug because it was constantly leaking.
OdiN
Banned
Mar 1, 2000
16,430
Damn. 1/4" steel would add a lot of weight!
I know a guy that build rock sliders out of 1/4" steel. Heavy mfers. Not really needed. 3/16" would work fine.
Bignate603
13,897
The one over the oil pan isn't too bad. I've had the pan off a few times and it's not too bad. It's the t-case skid plate and gas tank skid plate that are worse. I doubt I could get them down without another person or two.
SoulAssassin
6,135
I take the t-case skid off my wrangler all the time, it's easy w two people. You could probably do it with one if you had a jack that would reach high enough though it might be a little awkward w two hands. Factory gas tank skid looks pretty light...off the top of my head I think it's only 1/8" but that one I've never taken off.
Bignate603
13,897
This was a custom plate, which is ridiculously thick. With two people and and a floor jack I think I could get it down though.
marvdmartian
5,444
27
Had a valve like that on a Camaro, years ago. Worried about it for maybe the first year, constantly checking under the car to make sure it wasn't getting hit by anything (since that car hung lower than most), and never saw any evidence that it was being damaged.
Best thing about having one? Never dropping the oil drain plug in the tub of hot oil again! :)
