is the heatsink on the board suppose to be loose? i notice it was loose when putting my hdd in and it accidently bumped against the heatsink and a side of it came up a little.
for the heatsink/fan that came with the a64 3000+, where do i plug the fan in? is it the CPU fan or the chip fan? i got kind of confused because i thought the cpu was the chip.
while installing the heat sink i had to take it off because it wouldnt clamp on the side. u can see the white thermal pad on cpu, i read if u reinstall a heatsink with a pad u need to apply grease. do i need to apply grease or is it ok because i havent actually used it yet?
thanks
thanks
