I wanted to pull the control pod off my klipsh so i could put the satelites farther away and keep the control by the desk. Just wanted to get a quick headsup on how to remove it...thanks.
simple no- brainer: looking at the front of the speaker with the pod, grip the bottom of the pod and slide it to the rear- it's just got a set of grooves in it that locks into pins sticking down from the speaker.
