Quick integration help - math
RESmonkey
4,818
How can I integrate this:
1 / sqr.root(4-x^2)
or just
(4-x^2)^(-.5)
It looks like an arcsine thing, but where did the four come from?
RESmonkey
4,818
I know the answer...I just wanted to see it done step by step with u substitution.
Ricemarine
10,507
sqrt(a^2-x^2) where x = a sin(theta),
from the identity 1 - sin^2(theta) = cos^2(theta)
so the 4 in your equation would = a^2, in which a = 2?...
(making an assumption, might be wrong)
Don't think it'd be much help though...
RESmonkey
4,818
Never mind...I figured it out:
If anyone wanted to know:
4-x^2
4(1-.25x^2)
rip the four outta of the sqrroot:
2(1-.25x^2)^.5
Rip 1/2 outta of the integral. use u substitution from there on out.
RESmonkey
4,818
Hmm...that kind of does parallel what I did. It might even be the same thing, dunno. :0
Ricemarine
10,507
***This is using my previous post***
( 1 / sqrt(4-x^2) )dx
x = 2sin(theta)
dx = 2cos(theta)
(1 / sqrt(4 - 4sin^2(theta))dx
since 1 - sin^2(theta) = cos^2(theta)
( 1/ sqrt(4-4sin^2(theta))dx = (1/sqrt(4cos^2(theta))dx
which then becomes
dx / 2cos(theta)
and since dx = 2cos(theta)
plug the thing into the integral and use U substitution from there...
Umm, might wanna double check if I'm wrong. My head's kinda iffy today.
bonkers325
13,076
1 / sqr.root(4-x^2)
or just
(4-x^2)^(-.5)
(4 - x^2)^(-.5) = [4 * (1 - x^2 / 4)]^-.5 = .5 * (1 - x^2 / 4)^-.5
so your integral takes the form of 1 / sqrt(1 - u^2) where u = x/2 and du = .5dx
so u look up the integral in a table or whatever and u get asin(x/2) + c
edit: you were on the right track but u need to remember that u when u can break down equations into simpler pieces, you should do it.
Ricemarine
10,507
Originally posted by: Fenixgoon
looks good so far
edit: ricemarine, wtf are you doing his hw?
No, I'm just copying the example, writing step by step of what I try and do to solve it with the help of my calculus book, and posting it on a forum, specifically the topic which originally had the example...
Plus, he already solved the problem before I posted that. :)
RESmonkey
4,818
Yikes. My grade for last q was a B+ ....an 89.something percent. Grr...I've never gotten anything but A's in math/science :(
I gotta average out an A for the semester.
