Quick help
furie27
684
Can two wireless router/hubs be "piggy backed" via their wireless connection? Was hoping to have one on both floors of the building.
Goosemaster
48,775
As in connect two wireless Access points together to create a virtual "cable": yes
The problem is that product your has a built in access point. These products sometimes omit certain features for the sake of price reduction. THis means that your router/AP might not have this function. Even my cheap true access point doesn;t support this feature.
Look up: wireless bridging.
If you want to use two wireless network cards instead(almost always possible) , look up : ad-hoc
Good luck
