Hey, Ive had my computer running perfectly for about 5-6 months now without any problems. Specs are:
AMD 64 3200+ (@2.4ghz)
Asus K8V SE Deluxe
Corsair XMS PC3200 RAM
eVGA 6800GT
160GB Seagate SATA
Antec 550W Power Supply (tru550)
I just recently today added these two blue cathodes into the case, and it was up and running perfectly. While the computer was on, I was just hiding some wires but I dont think anything happened. The connection was loose on the cathodes inverter type thing, so I tried to make sure it was in all the way, and then it just made a spark and a tiny tiny bit of smoke. I turned off the computer, unplugged it, replugged it in and it was okay. Then the computer turned off after a few minutes. I restarted it and then it turned of after a few seconds, and every time I try from now on when I switch off and on the switch on the back of the power supply, everything powers up for a split milisecond and then turns right off again.
Any idea what the problem could be? Could that cathode I added killed the Power Supply in any way possible?? I tried running it without any accessories besides the main things, and it still doesent work. Any ideas on anything that could possibly be making the computer turn off after a split second every time?
Thanks a lot in advance.
Asus K8V SE Deluxe
eVGA 6800GT
160GB Seagate SATA
