Quick help with a unix shell script?
I need to set a few environment variables before I run a certain program...how can I write a shell script to do this for me?
I tried to write a bash script that did something like "export MYDIR=/home/dir" but that did not set $MYDIR to what I wanted once the script was run.
please help?
the 'export MYVAL=blahblahblah' will set the env variable to that value. you do have to point the $MYVAL variable to the environment variable however, you can't just call the env variable name with a $ sign in front of it. You can do that by doing a $MYVAL = $ENV{'MYVAL'}
...when you do that command the $MYVAL value in your script will be set to the environment variable value that was exported to MYVAL
LET US KNOW if it works or not.
