Quick help with a t-83 calc..
platinumike
I pulled the batteries out, cleared the memory of the calc, and now it wont let me erase the default table inputs. (the table im reffering to is when you hit the 2nd key, and hit the graph button) I can move my cursor over the default table inputs but when i hite del or clear nothing happens! please help!
I dont think you're supposed to erase that. It's just there to give the actual function values at specified points.
EDIT: Press 2nd, Window (TBLSET) to change the x-values
Originally posted by: platinumike
right, I wanna erase the default x values, and be able to put in my own x values.
You can't. You can only set the intervals that the x values are in TBLSET which is 2nd Window.
