ok, Im stuck putting my new PC together. Maybe someone can help me with the front panel audio connector.
Here is the Epox 9NDA3+ Manual:
When the jumpers are removed this connector can be used for front panel audio. The front panel phone jack should have "normal close" switch. Without phone plug inserted, the rear panel audio is enabled. With phone plug inserted the rear panel audio is disabled.
try and picture these lined up in your mind with jumpers on the bolded pins..
mic in [] [] gnd
nc [] [] +5v
front line out R [] [] rear line out FR
[] [x] key
front line out L [] []real line out FL
pins (5-6) & (9-10) short (default): only the onboard rear panel audio jack can be used.
pints (5-6) & (9-10) open: only front panel audio jack can be used
OK - Now from the case instructions. It has a green and red jack on the front and the following connectors:
These are all seperate - I just need to know which goes where so I can use headphones from the front but keep my normal speakers plugged in the back
[] L-OUT brown
[] RET-L red
[] R-OUT orange
[] RET-R yellow
[] MIC PWR black
[] MIC IN green
[] GROUND black
Thanks
mic in [] [] gnd
nc [] [] +5v
[] [x] key
[] L-OUT brown
[] RET-L red
[] R-OUT orange
[] RET-R yellow
[] MIC PWR black
[] MIC IN green
[] GROUND black
Thanks
