Okay, so we have two switches i our bathroom and one of them went out. There are three main wires flowing to the switch. Each one has a white a black and a copper (I assume grounding is copper). The old switches don't tell which one is positive and which is negative so I'm not sure which one to go with. Also I want to know if the contractor did the wiring right.
Ok so from these three wires, all three of the copper wires connect together and are attached to a screw. 1st question is, do I need to connect the ground wire from the switch(on the old ones none of hte ground wires are attached)?
Second Question is, on a conventional switch (mine is labeled on and off), would the red (positive right?) go to the top or the bottom? If I know this I can identify negative and positive! Thanks
