quick help in excel
skisteven1
537
I've got a column of dates that are formatted as such:
'03/15/1988'
'03/17/1988'
'04/02/1992'
.....etc
I'd like to sort them by date. If I can remote the apostrophe on each end, then it shoudln't be a problem. I feel like there really ought to be an easy to way to apply expressions to groups of cells in excel, but I don't know how.
Any suggetsions?
HN
8,186
4
select column -> data -> sort -> column [whatever the column is] -> Ascending / Descending.
i just did it with the apostrophes in place and it still worked.
Ghouler
442
1) press ctrl+H
in the first line enter this sign you want to get rid of :
leave the other line blank
hit "replace all" button
2) Then mark whole column
press ctrl+1
select number tab, select "date", pick any format you want
3) Sort column whatever way you want now
Does ot work now?
bruceb
8,874
111
Do you have the cells formated as DATE FORMAT ? ?
Select the format that shows as 3/14/2001 in the drop
down list ... When you enter the DATES, if you want the
leading zero to show for months Jan thru Sept hit the '
key first then type in the date ... the zero will stay but the '
will not show
