quick, dumb question.... regarding hd and partitions...
gopunk
29,239
in partition magic, it shows my main partition, then there is like 8 mb of unallocated space. is this normal? can i merge the two? not like i need the space, but it just kind of bothers me...
jthsmak
732
if you partitioned it with the windows cd it leaves off 8 megs. I wouldnt resize it, pmagic destroys partitions alot when you do this. Its only 8 megs.
