What is the experimental yield (in grams) when the percent yield is 11.01 % when 84.4 g of barium nitrate reacts in solution with excess sodium phosphate?
I have done this a hundred times and can't seem to figure it out. I know the formula is:
% Yield = Actual Mass/Theoretical Mass X100%
But simply plugging in the numbers in this equation can't be the only thing that is required.
When I create the equation:
Ba(NO3)2 + Na3+PO4
I then balance it:
3Ba(NO3)2 + 2Na3(PO4) --> 6Na(NO3) + Ba3(PO4)2
I don't know where to begin with the given 84.4gBa(NO3)2. I could start an equation like:
84.4gBa(NO3)2 * (1mol Ba(NO3)2 / 261.32g Ba(NO3)2)
to get its molar mass but I have absolutely no idea where to go from here. Any help appreciated.
Ba(NO3)2 + Na3+PO4
I then balance it:
Old/previous ANSWERED question:
What is mass (in g) of copper can be recovered from 57.4 mL of a 0.669 M solution of copper(I) chloride and excess hydrogen?
Wouldn't it be 9.0x10^23?
Because this is what I would do:
1. Create the equation: CuCL + H2 --> HCL + Cu
2. Balance it: 2CuCL + H2 --> 2HCL + 2Cu
3. Start the problem:
57.4mL(CuCL) * (1L(CuCL)/1000mL(CuCL)) * (1mol(CuCL)/1L(CuCL)) * (1mol(Cu)/0.669mol(CuCL)) * (6.022x10^23g(Cu)/1mol(Cu)) = 9.0x10^23 grams of Cu.
Am I working on this correctly? If not, where am I going wrong? Thanks.
