Quick CD-ROM cable question
Yossarian
18,010
My CD-ROM has both analog and digital outputs, and my sound card has both inputs. Can I connect both cables at the same time, or are they mutually exclusive?
Is there any point to connecting one of the cables to my burner?
Thanks in advance.
Vinny N
2,277
Never tried using both at once.
(I guess you would if you used your computer with another operating system in which the drivers don't support muting/unmuting digital cd audio from your sound card)
If both were working(believe it or not, some CD-ROM drives are manufactured with both connectors, but the digital isn't actually enabled) then I would simply use the digial output for cleaner sound.
To your burner from your CD-ROM? Definitely doesn't do anything.
From your burner to your soundcard? Sure, then you can get cd audio from your burner :)
