More than a month ago, I checked my car's oil and it was kinda black and it's 1000 miles before it's due to be changed. So, today I checked it again and it fell below the LOW point which obviously I have insufficient oil in the engine. It was exactly between the High and Low point the last time I checked. How would it possibly gone way below the Low point in 1.5 months when it had been between the High and Low point for the last 5 months.
Should I be worried??
:Q
Your car is not going to last long. What kind of car is it?
You didn't check your oil in a month and a half and you're surprised the oil level moved? Christ, you're supposed to keep it at FULL all the time.
Change your oil. NOW. It is full of garbage.
Yes yes!!!!! Mitsu Galant 97. I was surprise cause it was always at the mid level for almost 5 months! Then 1 month plus.....boom.it went down??.....wtfffffffffff...........
Well, when you post a thread about how Mitsubishi sucks and your engine has breathed its last intake, and it's going to cost 2500$ for a new one...
I'm going to pull up this thread, and we're all going to laugh at you.
I won't.
🙂 This car is going out pretty soon. I got this car for 3500 man. It's cheap for a car like that.
Why kill it just by being lazy though? You know it
is going to break down sometime, probably at a time when you're really going to care. I don't know about you, but 3500$ isn't a small chunk of change...
Oh, and about the smoke.. It is indeed blue.
I mean.. it's not like it's sky blue or something, lol.. It's a smokey grey-blue. Coolant burning is white, but don't mistake the steam type stuff comming out of the exhaust pipe before everything is warmed up to be smoke.
Just look for it next time you go down the street. You'll see some piece of sh!t minivan or other automobile that could double as a mosquito fogger. Look for it at lights, it's particularly bad on acceleration.
