quick and dump NF2 dual display question.
Hottie
I have NF2 MB with on board video, if I am going to add a video card into it should I buy AGP card or PCI card? And after the new card which one will be 1st display and 2nd display?
thx
most videocards have dual display, if you want 3 then you need a pci card probably, if you get an agp card you should disable the integrated graphics which will put reduce stress on your board and run cooler as well as increase the overclock potential
