quick and dirty current controlled led dimmer
Status
Not open for further replies.
PottedMeat
12,363
475
Heh nice, very similar to mine. I've got 3 of those connected to 1W lensed luxeons in kind of a hydra looking lamp. Mine has the sense resistance cut down to ~1/3 ohm I think and higher gain on the amp. You may not need that MOSFET driver or the 5V regulator though.
That MCP34063 is a handy chip. Buck, Boost, Inverting, all in one.
May 11, 2008
23,378
1,576
You are right, i AHHRUMM (whispering) : "overdimensioned" it a bit. I had the parts laying around and was thinking of some feature use when upgrading the coil and other components.
But in all honesty : When it needs to be small, integrated solutions are avaliable :
For example the CAT4xxx series from ON semi.
ZXLD1362. from diodes inc.
http://www.diodes.com/datasheets/ZXLD1362.pdf
http://www.onsemi.com/PowerSolutions/parametrics.do?id=197
Status
