QUICK AGP help--9600pro or 6200?
Toddo97
I'm looking to buy a card for a friend w/in the hour. I'm looking at around the $50 mark--no gaming or anything so looking for a pretty basic card. Both of these are about the same price--which would you recommend? Thanks!
May 30, 2007
1,446
The 6200's at newegg are 64 bit memory versions which would not be able to contend with the 9600 Pro.
There's also this 6800XE which would be arround the same speed as a 6600 non GT which would provide performance about that of a 9700 non pro. Keep in mind that 6800XE is a bare card only.
