Questions regrding my build
slayerized
I am trying to build a C2D based system and I got all my parts together last week. I am having some trouble powering on the system. The PSU fans don't seem to go on and I dont think there is any power supply to the board. I tried the age old trick to see if the PSU may be functional; by shorting the green with the ground and then the fan does go on. I have a Gigabyte-965P-DS3 board with E6600 and Zalman cooling. The RAM i am using is G.Skill DDR2 800: F2-6400CL4D-2GBPK. I also have a Sapphire Radeon 1950 pro graphics card.
I have also tried the following:
- Checked the jumper connections from the case for power and reset
- Assembling the bare minimum components outside the box; no avail
- Placing one module of memory at a time
I really dont know whether the problem is with the PSU, memory or the board. Will the PSU turn on irrespective of whether the memory units are good/bad? Is there any other way to diagnose the part which is failing. Any help/inputs would be appreciated. This is my first build in a long time (the last being a Celeron system way back in 2000 i guess).
A lot of boards I had at least had a small LED indicator on board suggesting some power is on board (not necessarily sufficient power). But I guess the boards these days do not come with that LED; or I am not sure if theres one in DS3 and I cant locate it. The whole RMA process is frustrating and I need to be sure which component is faulty before going ballistic and RMAing all the individual components!
It would be great if someone could answer the question I had asked previously --> Will the PSU turn on even if the RAM modules are faulty?
yes, your psu will turn on automatically, even with two bad memeory modules. Run the program Memtest to see if you have faulty memory.
To go to the Memtest stage of things I first need to atleast fire up my rig! I guess I will have to wait for a replacement board to arrive to do that.
Even my mobo has a small LED light at the bottom to tell me when the rig is on. Have you double checked that there is no small led light on the mobo for power?
OK! Finally I re-assembled the rig after jump starting the PSU and bam I see the start up screen! Thanks for your feedback
